Справочник строителя | Лист
МАССА ЛИСТОВ ИЗ КОРРОЗИОННОСТОЙКОЙ СТАЛИ
SS 2333-28 SS 2343-28 DIN 50049/3.1 В
Толщина листаS, мм |
Раскрой а х b,мм х мм |
Вес листам2, кг |
Толищина листаS, мм |
Раскройа х b,мм х мм |
Вес листам2, кг |
| 0,5 | 1000x2000 | 8 | 6,0 | 1500x3000 | 216 | |
| 0,8 | 1000x2000 | 13 | 1500x6000 | 432 | ||
| 0,8 | 1250x3000 | 24 | 2000x6000 | 576 | ||
| 1500x3000 | 29 | 8,0 | 1500x3000 | 288 | ||
| 1,0 | 1000x2000 | 16 | 1500x6000 | 576 | ||
| 1250x2500 | 25 | 2000x6000 | 768 | |||
| 1250x3000 | 30 | 10,0 | 1500x3000 | 360 | ||
| 1500x3000 | 36 | 2000x6000 | 960 | |||
| 1,25 | 1000x2000 | 20 | 12,0 | 1500x3000 | 432 | |
| 1250x2500 | 31 | 2000x6000 | 1152 | |||
| 1250x3000 | 38 | 15,0 | 1500x3000 | 540 | ||
| 1500x3000 | 45 | 1500x6000 | 1080 | |||
| 1,5 | 1000x2000 | 24 | 2000x6000 | 1440 | ||
| 1250x2500 | 38 | 20,0 | 1500x3000 | 720 | ||
| 1250x3000 | 45 | 1500x6000 | 1440 | |||
| 1500x3000 | 54 | 2000x6000 | 1920 | |||
| 2,0 | 1000x2000 | 32 | 25,0 | 1500x3000 | 900 | |
| 1250x2500 | 50 | 1500x6000 | 1800 | |||
| 1250x3000 | 60 | 2000x6000 | 2400 | |||
| 1500x3000 | 72 | 30,0 | 1500x3000 | 1080 | ||
| 2000x4000 | 128 | 1500x6000 | 2160 | |||
| 2000x6000 | 192 | 2000x6000 | 2880 | |||
| 2,5 | 1000x2000 | 40 | 35,0 | 1500x3000 | 1260 | |
| 1500x3000 | 90 | 1500x6000 | 2520 | |||
| 3,0 | 1000x2000 | 48 | 2000x6000 | 3360 | ||
| 1250x3000 | 90 | 40,0 | 1500x3000 | 1440 | ||
| 1500x3000 | 108 | 1500x6000 | 2880 | |||
| 2000x4000 | 192 | 2000x6000 | 3840 | |||
| 1500x6000 | 288 | 45,0 | 1500x3000 | 1620 | ||
| 4,0 | 1000x2000 | 64 | 50,0 | 1 500x3000 | 1800 | |
| 1500x3000 | 144 | 1500x6000 | 3600 | |||
| 1500x6000 | 288 | 2000x6000 | 4800 | |||
| 2000x6000 | 384 | 60,0 | 1500x3000 | 2160 | ||
| 5,0 | 1500x3000 | 180 | 2000x6000 | 5760 | ||
| 1500x6000 | 360 | 70,0 | 2000x5000 | 5600 |
Примечание:
Вес листа рассчитан исходя из плотности стали 8 г/см3
